I’m new to telegraf. That being said,
I’m trying to parse some mqtt topics with telegraf, with the (later) goal to import them into influxDB. The mqtt topics are like this:
mqtt_consumer,host=xxxx,topic=mtr/hzg/temp value="24.8" 1680447906430751221
mqtt_consumer,host=xxxx,topic=mtr/pwr/evu/SENSOR value="{\"Time\":\"2023-04-02T17:05:07\",\"EHZ541\":{\"cnt_imp\":3648.8,\"cnt_exp\":213492.8,\"mtr_cur\":-554}}" 1680447908136350043
They are either simple topic / value pairs (like the first one) or contain some JSON as payload.
The following telegraf.conf created above snippet.
[global_tags]
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = "0s"
hostname = ""
omit_hostname = false
[[outputs.file]]
files = ["stdout"]
[[inputs.mqtt_consumer]]
servers = ["tcp://127.0.0.1:1883"]
topics = [
"mtr/hzg/#",
"mtr/pwr/evu/SENSOR",
client_id = "telegraf"
username = "UUUUUUU"
password = "PPPPPPPP"
data_format = "value"
data_type = "string"
By replacing data_type with float, all good for the topic “mtr/hzg/#”.
Next, trying to parse JSON with the addition of the following config line (just appended to above config file)
topics = [
username = "UUUUUUUU"
password = "PPPPPPPPP"
data_format = "json_v2"
[[inputs.mqtt_consumer.json_v2.object]]
tags = [ "cnt_imp" ]
[[inputs.mqtt_consumer.json_v2.fields]]
cnt_imp = "float"
cnt_exp = "float"
mtr_cur = "float"
It produces the following result
2023-04-02T15:17:30Z I! Loading config file: /etc/telegraf/telegraf.conf
2023-04-02T15:17:30Z E! error loading config file /etc/telegraf/telegraf.conf: plugin inputs.mqtt_consumer: line 28: configuration specified the fields ["fields"], but they weren't used
What am I missing??
Joe
