JSON parsing help
Hi. I have the following payload ;
                  "channel": 1,
                  "value": 22.54,
                  "type": "temp",
                  "unit": "c"
                  "channel": 2,
                  "value": 41.2,
                  "type": "rel_hum",
                  "unit": "p"
and the following telegraf config ;
    data_format = "json"
    json_string_fields = [ "type","unit" ]
        topic = "+/+/+"
        tags = "site/room/client_id"
Problem is that only the last item of the JSON array gets to my influxdb. How can I fix that and should I use json_v2 instead of json data_format?
Apart from the json parser configuration, that seems to be not a valid json!?
What are these values stemp, shumi under the value key?
This example should work, adjust it to your needs:
[[inputs.mqtt_consumer]]
  # the mqtt plugin config here
  data_format = "json_v2"
    [[inputs.mqtt_consumer.json_v2.object]]
      path = "@this"
      tags = ["type"]
      [inputs.mqtt_consumer.json_v2.object.fields]
        channel = "int"
        value = "float"  # is this a float value?
        unit = "string"
stemp , shumi are variable holding the value for temperature and humidity, variable type is float.
why do you say it’s not a valid json?
Can I keep this?
I publish to this topic format “house/room/client_id” to get the site, room and client unique id.
Because the json parser need real values, not variables.
So i assume, what you showed was a template, not the real payload.
Yes, you have to keep this, because the mqtt topic parsing is independent from the json parsing of the payload.
Great, your help is really appreciated!
made the changes and I still get only the ‘rel_humi’ data, no ‘temp’ in influxdb…
I have a basic file output that is fine, each publish generate two lines of data.
I use influxdb 1.8.10 and I check the measurements with the following query ;
use mydatabase
select * from mqtt_consumer
Then we need your full mqtt input plugin config and a sample snippet of your real json data.
