Dear community,
novice here. I’m struggling with something that looked easy at first glance…
I’ve a MQTT device that sends this json payload, under /tele/floor1/SENSOR
{Time":"2024-01-03T15:17:18",
"devType":"EBC",
"EBC":{"Temperature":19,"Humidity":50},
"PressureUnit":"hPa","TempUnit":"C"}
I can correctly parse this using this configuration
data_format = "json_v2"
topic = "tele/+/SENSOR"
tags = "_/device/_"
timestamp_path = "Time"
timestamp_format = "2006-01-02T15:04:05"
timestamp_timezone = "CET"
measurement_name = "data_from_device"
[[inputs.mqtt_consumer.json_v2.object]]
path = "EBC"
path = "EBC.Temperature"
type = "float"
path = "EBC.Humidity"
type = "float"
Now… sometimes the device may have an additional sensor so the payload becomes this
{"Time":"2024-01-03T15:17:18",
"devType":"EBC2",
"BMP280":{"Temperature":20.4,"Pressure":1006.0},
"EBC":{"Temperature":20,"Humidity":60},
To handle the new values i’ve created one more config file which looks similar to the other
path = "BME280"
path = "BME280.Temperature"
type = "float"
path = "BME280.Pressure"
type = "float"
No luck. Data get all merged down and I only see one value for temperature humidity or pressure, meaning that I can’t distinguish the different sensors.
I think I should use tags but I dont know how.
Thanks in advance!
