I am looking for a bit of help with configuring Telegraf for parsing Json data. Say, my input data is sent as
"measurements": [
"name": "temperature",
"value": 23.4,
"units": "℃"
"name": "moisture",
"value": 5,
"units": "%"
"name": "light",
"value": 10118,
"units": "lux"
"name": "fertility",
"value": 0,
"units": "us/cm"
"name": "time",
"value": 1555745371410,
"units": "ms"
and the Telegraf Json parser is configured as
json_query = "measurements"
tag_keys = [
"name",
"units"
then everything looks quite nice:
> select * from mqtt_consumer
time host name topic units value
1555745371450794118 *** temperature iot-2/type/TeMoLiFe/id/c67c8dfffe65cb63/evt/PubState/fmt/json ℃ 24.3
1555745371450808740 *** moisture iot-2/type/TeMoLiFe/id/c67c8dfffe65cb63/evt/PubState/fmt/json % 6
1555745371450815925 *** light iot-2/type/TeMoLiFe/id/c67c8dfffe65cb63/evt/PubState/fmt/json lux 10168
1555745371450822476 *** fertility iot-2/type/TeMoLiFe/id/c67c8dfffe65cb63/evt/PubState/fmt/json us/cm 58
1555745371450828165 *** time iot-2/type/TeMoLiFe/id/c67c8dfffe65cb63/evt/PubState/fmt/json ms 1555745371375
1555745371505989365 *** temperature iot-2/type/TeMoLiFe/id/c67c8dfffe65d020/evt/PubState/fmt/json ℃ 23.4
1555745371506015142 *** moisture iot-2/type/TeMoLiFe/id/c67c8dfffe65d020/evt/PubState/fmt/json % 5
1555745371506029556 *** light iot-2/type/TeMoLiFe/id/c67c8dfffe65d020/evt/PubState/fmt/json lux 10118
1555745371506043834 *** fertility iot-2/type/TeMoLiFe/id/c67c8dfffe65d020/evt/PubState/fmt/json us/cm 0
1555745371506056170 *** time iot-2/type/TeMoLiFe/id/c67c8dfffe65d020/evt/PubState/fmt/json ms 1555745371410
besides that I am not sure how to extract the time value into the time column.
If I change the input json to
"time": 1555745371410,
"measurements": [
"value": 23.4,
"units": "℃"
"name": "moisture",
"value": 5,
"units": "%"
"name": "light",
"value": 10118,
"units": "lux"
"value": 0,
"units": "us/cm"
then I can get the time value in the time column with
data_format = "json"
json_time_key = "time"
json_time_format = "unix_ms"
but I do not know how to extract sensor data as nicely as above. What should be in the json_query field then?
Thank you!
