i am new to influx and i have the following question:
How do i create an API Key ??
I´m running Influx 1.8 and i want to do some Queries from Excel to the Influx-Database. The Influx-Database runs on an Ubuntu-System and i have SSH-Access to the Machine.
Hello @Chakoe,
Welcome!
If you’re running 1.x locally,
You shouldn’t need a token. You can just do:
curl -XPOST "localhost:8086/api/v2/write?bucket=db/rp&precision=s" \
--data-raw "mem,host=host1 used_percent=23.43234543 1556896326"
For example.
If you do have auth enabled you'd do:
