Hi experts,
I have a hard time going from Python “influxdb” package 5.3.0 to new Python “influxdb-client” package 1.11.0. With the new version of the Python API package, the client exclusively connects via JWT authentication token. However, I am completely unexperienced in this matter and quite lost.
The documentation (Authentication and authorization in InfluxDB | InfluxDB OSS 1.8 Documentation) tells me to create my own JWT token via http://jwt.io - which (seems to) work(s).
For the token creation I use my former user / password to create the token in the following way - header:
"alg": "HS256"
"typ": "JWT"
The payload looks like this:
"username": "the_user_name",
"exp": 253402214400 (comment: 9999-12-31)
In the “verify signature” I use the following:
HMACSHA256(
base64UrlEncode(header) + "." +
base64UrlEncode(payload),
<password of the_user_name in InfluxDB>
If I define the “shared-secret” in the [http] section of the /etc/influxdb/influxdb.config file like:
shared-secret = <password of the_user_name in InfluxDB>
and use the token generated via http://jwt.io I can perform successful curl calls like:
curl -XPOST "http://myserver:8086/query?db=mydb" --data-urlencode "q=SHOW SERIES" --header "Authorization: Bearer <token created via jwt.io>"
However, when I use the same token in my Python code:
influx_client: InfluxDBClient = InfluxDBClient(url=server_address + ':8086', use_udp=False,
token=<token from jwt.io>)
influx_client.query_api().query_data_frame(sql_like_query_statement)
I get an
influxdb_client.rest.ApiException: (401)
Reason: Unauthorized
HTTP response headers: HTTPHeaderDict({'Content-Type': 'application/json', 'Request-Id': '3d843831-0cb5-11eb-8005-02ff0a0a2610', 'Www-Authenticate': 'Basic realm="InfluxDB"', 'X-Influxdb-Build': 'OSS', 'X-Influxdb-Version': '1.8.0', 'X-Request-Id': '3d843831-0cb5-11eb-8005-02ff0a0a2610', 'Date': 'Mon, 12 Oct 2020 18:03:32 GMT', 'Content-Length': '55'})
HTTP response body: b'{"error":"unable to parse authentication credentials"}\n'
What am I doing wrong?
