is it possible to write data via a HTTP(s) POST request into influxDB 2.7 with only the user & pw instead of the long token?
Regards Matthias
Regards Matthias
Try the below one:
data
|> to(
bucket: "example-bucket",
org: "example-org",
userid:
password:
host: "https://myinfluxdbdomain.com/8086",
Thanks for your Help.
I use the Arduino Framework and Libs. That is my actual code:
POST /api/v2/write?org=&bucket=&precision=s HTTP/1.1
Host: 192.168.1.15
Authorization: Basic VXNlcjpQYXNzd29ydA==
Content-Type: text/plain
User:passwort == (base64) VXNlcjpQYXNzd29ydA==
but with this settings the data will not store in Database. Where is the failure?
