Unauthorized access when I try to write datas
Hi, I write data with a token is pretty well.
When I switch to username / password, I got unauthorized access event.
language : c#
_client = InfluxDBClientFactory.Create(url, _token.ToCharArray());
_client = InfluxDBClientFactory.Create(url, _user, _password.ToCharArray());
the API token is created for the user by the web UI.
OSS v2.0.7 / v2.4.0
Hi @Erikson,
thanks for using our client.
The preferred way to authorise is the token. Are you able to simulate your authorisation error?
Regards
Hi @bednar,
  thanks , and I will follow the way.
  Test case :
  .... passed
  var theAPI = _client.GetWriteApi(writeOptions);
  theAPI.EventHandler += ShowWriteEvent;
  ... when I try to write data
  theAPI.WritePoint(_point, _bucket, _org);
  .... I got error event (unauthorized access)
