We can’t view the configs and change the configs to create admin user with all previleges, because of which in result we are not able to use create database and ‘write_points’ methods as we get user permission error.
Hello @Nischay97,
Welcome!
I’m not sure I understand your problem. But can you try creating a new all access token and seeing if that resolves the problem? Which version are you using and which client library(?) are you using?
I have created the token still facing the same issue , I am using influx v2.7.1 and InfluxDBClient.
There are multiple client libraries which implement something called InfluxDBClient. For example, I use the python library called influxdb_client. I think an older one was just called influxdb and my understanding is that it does not work with v2.7.1.
