How to completly reinstall and setup InfluxDb 2.0 from the begining (I can’t do this, always InfluxDb starts from existing configuration after removing and instaling again InfluxDb)
I added ads-b template (I have installed and working FlightAware with dump1090 and dump1090exporter, everything works flawlessly, I have aircraft positions from my ADS-B radar), but as for the System board in the ADS-B Flight Tracker board there is no data despite the fact that with dump1090 export generates them.
Hello @marekpow,
That sounds like telegraf isn’t reporting any more not like there’s a problem with InfluxDB. Have you tried restarting telegraf with the config from that template?
Hello @marekpow,
It looks like you need to create a new token, and export it. I recommend going back into the UI under telegraf configurations and clicking setup instructions, It will walk you through doing just that.
Hello @marekpow,
You can create a token and edit the config and replace it with the token you’ve created. Then you can set the environment variable permanently in your bash_profile.
