I am running one container of Influxdb 2.0 and one container of telegraf and I am getting the user data and using telegraf as a plugin trying push into influxdb 2.0 but we are not getting the data in influxdb. We tried pushing data system data to an external file using telegraf and data is coming in the file. We tried taking that file and taking this file as input using telegraf plugin still we are not able to get data into the influxdb.
We tried to get the system metrics [[inputs.cpu]], [[inputs.disk]] and this data is coming in influxdb. We are getting internal metrics in influxdb as well.
When we put both [[input.cpu]], and our system data configuration in same telegraf.conf then we are getting data except for our system data.
System Information
Ubuntu - 19.02
Influxdb version - Quay
telegraf version - 1.15.3
Telegraf configuration
[agent]
internal = "10s"
debug = true
quiet = false
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:8086
##urls = ["http://influxdb:8086"]
urls = ["http://14.206.177.28:8086"]
namedrop = ["exe_*"]
token = "$INFLUX_TOKEN"
organization = "org_name"
bucket = "logs2"
namepass = ["exe_*"]
bucket = "logs"
[[inputs.kinesis_consumer]]
region = "provided"
access_key ="provided"
secret_key = "provided"
profile = "arn:aws:iam::666268854852:instance-profile/ec2_to_aws_admin"
streamname = "new_stream"
shard_iterator_type = "TRIM_HORIZON"
data_format = "csv"
csv_header_row_count = 1
csv_tag_columns = ["node","operatorName","type"]
csv_timestamp_column = "datetime"
csv_timestamp_format = "2006-01-02T15:04:05"
[[inputs.influxdb]]
urls = ["http://influxdb:8086/debug/vars"]
timeout = "5s"
name_prefix = "exe_"
[[inputs.cpu]]
percpu = true
totalcpu = true
collect_cpu_time = false
report_active = false
[[inputs.disk]]
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "overlay", "aufs", "squashfs"]
The log information of the telegraf
2020-11-27T09:33:21Z I! Starting Telegraf 1.15.3
2020-11-27T09:33:21Z I! Using config file: /etc/telegraf/telegraf.conf
2020-11-27T09:33:21Z I! Loaded inputs: cpu disk kinesis_consumer influxdb
2020-11-27T09:33:21Z I! Loaded aggregators:
2020-11-27T09:33:21Z I! Loaded processors:
2020-11-27T09:33:21Z I! Loaded outputs: influxdb_v2 influxdb_v2
2020-11-27T09:33:21Z I! Tags enabled: host=26e286667de4
2020-11-27T09:33:21Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:“26e286667de4”, Flush Interval:10s
2020-11-27T09:33:21Z D! [agent] Initializing plugins
2020-11-27T09:33:21Z D! [agent] Connecting outputs
2020-11-27T09:33:21Z D! [agent] Attempting connection to [outputs.influxdb_v2]
2020-11-27T09:33:21Z D! [agent] Successfully connected to outputs.influxdb_v2
2020-11-27T09:33:21Z D! [agent] Starting service inputs
2020-11-27T09:33:31Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2020-11-27T09:33:31Z D! [outputs.influxdb_v2] Wrote batch of 10 metrics in 26.832907ms
From the above logs, we can see logs output plugins are connected and data is being written on influxdb but we are seeing measurement in the influxdb related to our data.
