Merge duplicate data points
We have a periodic task that runs every 1 hour and fetch data from our warehouse of (48h) and push them to influxdb, this leads to duplicate data points, is there a way to merge/update/upsert/overwrite on influxdb ?
If the timestamp and tag values are same, the entries will be overwritten. Majority of the time it is the timestamp but it can also be the incorrect schema.
Thanks! is this a standard behaviour in all influxdb versions? we are using 1.2.4
I been using it since version 0.9 and have same experience when overwriting the data.
