I have an application where a Python API calls information from InfluxDB to be sent to a Cloud. In order to avoid redundant information I decided upon using a dirty bit concept.
Initially, all values are stored into the InfluxDB with a field status=0. Information is coming from a GPS device.
Information is stored as following:
gps,gateway=UMG3001,node=core,type=gps status=0 1527072593639895040
This data is stored continuously.
Query
I use in my Python API a wrapper class which has a method as follow:
def read_gps_points(self):
return self.db.query('SELECT "lat","lon","alt" FROM "gps" WHERE "status"=0 LIMIT 100')
Which provides me the required information set.
Once I adapt the output from the above mentioned query to be sent to the cloud, I would like to write the batch back to the DB but with status=1 indicating that this information is already uploaded and shouldn’t be queried.
I change the status to 1 and write this information as a batch back into InfluxDB.
batch = db.read_gps_points() # read 100 points
# Upload to cloud
# prepare to update
updated_batch = []
for each_measurement in list(batch)[0]:
each_measurement['status'] = float(1) # make `status=1`
# make all measurements convert to float
new_measurement = {
'measurement': 'gps',
'tags': {
'gateway': 'UMG3001',
'node': 'core',
'type': 'gps'
'time': each_measurement['time'],
'fields': each_measurement
updated_batch.append(new_measurement) # append to the list
db.update_set(updated_batch) # update the batch
where update_set(updated_batch) is as follows:
def update_set(self, incoming_set):
self.db.write_points(incoming_set,batch_size=len(incoming_set), database='test')
If I check using SELECT COUNT(*) FROM "gps" where "status"=0 I should expect the count to decrease because I am writing the information with the same timestamps but that is not the case
For SELECT * FROM gps LIMIT 100
1527072386612 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
1527072386612 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 0 gps
1527072389684 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
1527072389684 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 0 gps
1527072392668 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
1527072392668 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 0 gps
1527072395680 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
1527072395680 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 0 gps
1527072398618 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
1527072398618 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 0 gps
1527072401625 -5.6 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
1527072401625 -5.6 UMG3001 59.226371666666665 10.913943333333334 core 0 gps
1527072404663 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
1527072404663 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 0 gps
1527072407619 -5.5 UMG3001 59.226371666666665 10.913943333333334 core 1 gps
As you can see the same timestamp now have two entries; one with status=0 and one with status=1
Why is this the case? Please help
P.S.
I have been struggling with this issue for a couple of days now and you can find this question on StackOverflow with a 50 point bounty up for grabs.
