Hi!
I’m seeing duplicate records when, from the docs, I expect to overwriting to occur.
I had some data and (via python API) added more at the same _time with the same group key.
See below for a minimal example. I perhaps misunderstand, but expected _value to be overwrite. I now have a ‘duplicate’ point and can’t differentiate them.
I’ve tried
- restarting Influxd
- waiting 24h in case influxd does some background cleanup
- triple checking group key is the same value/type
Possibly related:
Probably related: the error I receive running a mean() :
runtime error @28:6-28:12: mean: aggregate found duplicate table with key: {_field=Watts,_measurement=iotawatt,_start=2023-07-20T16:07:32.890000000Z,_stop=2023-07-23T12:17:29.340000000Z,device=andrea,sensor=ConsumptionNet,units=Watts}
What am I missing?
Thanks, Brett
# The query,
from(bucket: "iotawatt")
|> range(start: 2023-07-23T12:22:50.44Z, stop: 2023-07-23T12:23:50.44Z)
|> filter(fn: (r) => r.device == "andrea" and
r.sensor == "Consumption"
# Result from "cat flux/double-point.flux | influx query
Result: _result
Table: keys: [_start, _stop, _field, _measurement, device, sensor, units]
_start:time _stop:time _field:string _measurement:string device:string sensor:string units:string _time:time _value:float
2023-07-23T12:22:50.440000000Z 2023-07-23T12:23:50.440000000Z Watts iotawatt andrea Consumption Watts 2023-07-23T12:23:00.000000000Z 4378.37
2023-07-23T12:22:50.440000000Z 2023-07-23T12:23:50.440000000Z Watts iotawatt andrea Consumption Watts 2023-07-23T12:23:00.000000000Z 4435.97
ps I am using
- Influx OSS on Ubuntu 22
Influx CLI dev (git: none) build_date: 2023-04-28T14:24:14ZInfluxDB v2.7.1 (git: 407fa622e9) build_date: 2023-04-28T13:24:27Z
