With the following tickscript why do I see duplicate values with same timestamp? Is this expected or is this because of line protocol?
I used median function to see if it handle the duplicates and it does, i get the correct median for even and odd numbers. Please confirm if there is anything i need to worry about.
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|httpOut('line_22') // Here i see only value
|window()
.period(2m)
.every(2m)
|where(lambda: isPresent("Percent_Processor_Time"))
|eval(lambda: "Percent_Processor_Time")
.as('Percent_Processor_Time_alias')
|log()
|httpOut('line_31') // Here i see 4 values being repeated thus for 2 min total values
Example:
No Duplicates debug from httpOut(‘line_22’)
"series": [
"name": "Processor",
"tags": {
"host": "test_machine",
"instance": "_Total",
"objectname": "Processor"
"columns": [
"time",
"values": [
"2019-10-18T10:08:00Z",
16.348915100097656
Duplicate 4 times debug from httpOut(‘line_31’)
"series": [
"tags": {
"columns": [
"time",
"Percent_Processor_Time_alias",
"objectname"
"values": [
16.348915100097656,
"Processor"
16.348915100097656,
"Processor"
16.348915100097656,
"Processor"
16.348915100097656,
"Processor"
"2019-10-18T10:09:00Z",
17.49864959716797,
"Processor"
17.49864959716797,
"Processor"
17.49864959716797,
"Processor"
17.49864959716797,
"Processor"
Here is how the log looks like:
ts=2019-10-18T15:39:59.983+05:30 lvl=info msg=“batch point” service=kapacitor task_master=main task=test_median node=log6 prefix= name=Processor group=host=test_machine,instance=_Total tag_host=test_machine tag_instance=_Total tag_objectname=Processor field_Percent_Processor_Time_alias=17.49864959716797 time=2019-10-18T10:09:00Z
Similar issues reported:
Question is:
Why do we see duplicate values with same timestamp?
How kapacitor handles them?
