I am using InfluxDB 2.0.3 OSS and trying to achieve multi-organization architecture with it.
I have created three organization configurations like below:
| Org1 | Org2 | Org3 |
| Input_bucket1 | input_bucket2 | input_bucket3 |
| output_bucket1 | output_bucket2 | output_bucket3 |
input measurement, output measurement, and field names are common
I am trying to run one task which should run one time and take the values from the input bucket corresponding to the organization and put the data into the same organization output bucket.
f = (input_bucket, output_bucket, organization) =>
(from(bucket: input_bucket)
|> range(start: 2022-01-05T04:00:00Z,stop:2022-01-05T05:00:00Z)
|> filter(fn: (r) => r["_measurement"] == input_measurement)
|> filter(fn: (r) => r._field =="field_name")
|> increase()
|> last()
|> drop(columns:["host"])
|> map(fn: (r) =>
r with
time: r._time,
_measurement: output_measurement,
_field: "Output_field",
_value: float(v:r._value) / 1.0,
|> timeShift(duration: -30m)
|> to(bucket:output_bucket,org:organization,timeColumn:"time")
f(input_bucket:"Input_bucket1",output_bucket:"output_bucket1",organization:"Org1")
f(input_bucket:"input_bucket2",output_bucket:"output_bucket2",organization:"Org2")
f(input_bucket:"input_bucket3",output_bucket:"output_bucket3",organization:"Org3")
Suppose I am running this task it shows input_bucket2 and input_bucket3 doesn’t exist. After doing more experiments I got to know I have to run three tasks belonging to each Orgs. This will lead to code duplication which will create extra overhead for us.
So, is there any way we can achieve this without having code duplication?
