Dear Experts,
I am running InfluxDB 2.1.1 Server: 657e183 Frontend: cc65325 on a PC running Debian 11.
I am using the UI to upload old data I formatted to line protocol (Data / Buckets / Add Data / Line Protocol). The file looks like this:
sensors,device=growatt,sensor=voltage value=277.1 1481382628880000000
sensors,device=growatt,sensor=power value=0 1481382628880000000
sensors,device=growatt,sensor=today value=2700 1481382628880000000
sensors,device=miflora,sensor=temp value=20.3 1481382904741000000
sensors,device=miflora,sensor=moisture value=17 1481382904741000000
If I just add a few lines manually (leave the precision to nanoseconds), the data is written into the database. I know these are old records from 2016, but I have the retention policy set to Forever.
Next if I upload the entire file (9MB, 136K lines), I just get a generic error that it failed. I have 8 of these files, so already did lot of trimming so each file is less than 10MB.
Is there any way to tell which line has caused the error? I generated these lines in Excel using simple string concatenation, I am pretty sure there are no illegal characters, or for example spaces in the tag values.
Thanks a lot,
Csongor
