Can't import line protocol file with timestamp in influxDB UI
I am currently using InfluxDB version 2.7.1, and I am encountering an issue while attempting to import a line protocol file named lp.txt via the user interface (UI). Here is the content of the file:
myMeasurement,tag1=value1,tag2=value2 fieldKey="fieldValue" 1556813561098000000
myMeasurement,tag1=value2,tag2=value2 fieldKey="fieldValue2" 1556813561198000000
Interestingly, when I remove the timestamps, I can successfully import the file by simply dragging and dropping it into the UI. However, I encounter an error when I attempt to upload the file with timestamps. The error message I receive is as follows:
Failed to write data - invalid line protocol submitted
Although, I am able to manually enter same data with timestamps without any problems, therefore, it doesn’t appear to be a problem related to timestamps.
You managed to figure out the root cause? 3 years later and I have this exact problem too :frowning:
A common issue people run into with LP file uploads is the newline sequences. Was the file you’re uploading created on a Windows machine? If so, it’s likely using \r\n (carriage return + newline) instead of just \n. The carriage return breaks line protocol.
However, if the both the file with timestamps and the one without were created on a Windows machine, I would expect them both to fail when uploading to the UI :thinking:
Convert the file to Unix line endings (dos2unix lp.txt) and retry. You can check for hidden carriage returns with cat -A lp.txt; ^M at line ends means CRLF. Those 19-digit timestamps are nanoseconds, which is the default line protocol precision.
