Having an issue summing these two queries with the Grafana transform, wondering if there was a better way. Here are the queries:
from(bucket: “my-bucket”)
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) =>
r.resourceName == “AvgMotorCurrent1”
|> drop(columns: [“_start”, “_stop”])
|> map(fn: (r) => ({r with _value: ((r._value * float(v:720)) + float(v:208)) / float(v:1000)}))
|> sum()
|> map(fn: (r) => ({r with _value: r._value * ${cost}}))
|> last()
|> filter(fn: (r) =>
r.resourceName == “AvgMotorCurrent2”
|> sum()
|> last()
It returns the correct values I just need to add them together to get a sum. Any suggestions?
Anaisdg
February 27, 2024, 12:31am
2
Hello @Ryebot33 ,
Yes!
I’m not sure why the grafana transform isnt working. But you could alternatively do something like this in flux:
// Define a function to apply the common transformations
applyTransformations = (table) =>
table
|> drop(columns: ["_start", "_stop"])
|> sum()
|> last()
// Fetch and transform data for AvgMotorCurrent1
current1 = from(bucket: "my-bucket")
|> filter(fn: (r) => r.resourceName == "AvgMotorCurrent1")
|> applyTransformations()
// Fetch and transform data for AvgMotorCurrent2
current2 = from(bucket: "my-bucket")
|> filter(fn: (r) => r.resourceName == "AvgMotorCurrent2")
// Combine the results and sum the _value fields
union(tables: [current1, current2])
|> sum(column: "_value")
scott
February 27, 2024, 12:39am
3
@Ryebot33 And here’s another alternative:
This method creates a function that returns the total sum of a specified resource as a scalar value. It then adds the sums of your two resources and includes them in an ad hoc table created with array.from().
import "array"
getResourceSum = (resource) =>
(from(bucket: "my-bucket")
|> filter(fn: (r) => r.resourceName == resource)
|> map(fn: (r) => ({r with _value: ((r._value * 720.0) + 208.0) / 1000.0}))
|> sum()
|> last()
|> getColumn(fn: (key) => true, column: "_value"))[0]
totalResourceSum = getResourceSum(resource: "AvgMotorCurrent1") + getResourceSum(resource: "AvgMotorCurrent2")
array.from(
rows: [
{_time: v.timeRangeStop, _value: totalResourceSum},
