Tiki10
March 29, 2022, 4:28am
1
I’m trying to add two values (bytes-in + bytes-out) in flux only as Grafana transform is not working as I need.
My query is :
import “date”
month = date.truncate(t: now(), unit: 1mo)
from(bucket: “telegraf/autogen”)
|> range(start: month)
|> filter(fn: (r) => r["_measurement"] == “snmp_interfaces” and r[“hostname”] == “$hostname” and r._field =~ /bytes-/)
|> last ()
|> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: “_value”)
|> map(
fn: (r) => ({
_time: r._time,
_measurement: r._measurement,
_field: “totalConso”,
_value: int(v: bytes-in + bytes-out)
I’v tried to do it like it’s wrote in documentation, but that didn’t work as expected.
I have this error : invalid: compilation failed: error at @13 :34-13:36: invalid expression: invalid token for primary expression: IN error at @13 :39-13:44: invalid expression @13 :34-13:36: in
Does someone could help me with that ?
Regards
Tiki10
March 31, 2022, 8:15am
2
I “up” this topic because I haven’t found the solution to this problem.
Can someone could help me with this ?
Regards,
Tiki10
March 31, 2022, 12:13pm
3
Following advice on slack, I changed the query like that :
import "date"
from(bucket: "telegraf/autogen")
|> range(start: month)
|> filter(fn: (r) => r["_measurement"] == "snmp-interface")
|> filter(fn: (r) => r["host"] == "${hostname}")
|> filter(fn: (r) => r["host"] == "${Interface}}")
|> filter(fn: (r) => r["_field"] == "bytes-in" or r["_field"] == "bytes-out")
|> map(fn: (r) => ({ _value: r.bytes-in + r.bytes-out }))
|> sum()
But I still have de same error
Regards
Tiki10
March 31, 2022, 1:03pm
4
Hey,
In telegraf, I moved from bytes-in to bytesIn and rewrite my queries.
Everything is working now.
I don’t know if it’s the “-” ou “in” which if the problem.
Regards,
Vincent
ypnos
April 1, 2022, 11:05am
5
Probably it would work if you used r["bytes-in"] + r["bytes-out"].
The dot notation is just syntactic sugar and it doesn’t work for all column names as you can see.
Here is what you had just written with different spacing. Spot the problem?
_value: r.bytes - in+r.bytes - out
Tiki10
April 4, 2022, 10:08am
6
@ypnos .
Thank you for the tips. I’ll keep it for futur.
I still have a flux problem.I have 2 queries : The first one show the traffic evolution during the current month
The second should be the sum of in and out bytes.
As you can see, I should have around 6GB, but I got 102.
My queries are:
import "date"
|> range(start: month)
|> filter(fn: (r) => r["_measurement"] == "snmp_interfaces")
|> filter(fn: (r) => r["hostname"] == "${hostname}")
|> filter(fn: (r) => r["if-name"] == "${Interface}")
|> filter(fn: (r) => r["_field"] == "bytesIn")
|> map(fn: (r) => ({r with _value: r._value / 1073741824}))
|> increase()
import "date"
|> range(start: month)
|> filter(fn: (r) => r["_field"] == "bytesOut")
|> increase()
For the evolution and
import "date"
|> range(start: month)
|> filter(fn: (r) => r["_field"] == "bytesIn" or r["_field"] == "bytesOut")
|> last ()
|> map(fn: (r) => ({r with _value: (r.bytesIn + r.bytesOut) / 1073742824 }))
|> sum ()
For the sum.
What I doing wrong with the second query ?
Regards,
ypnos
April 4, 2022, 10:22pm
7
What do you use last() for?
As you are calculating the overall sum, you also don’t need to pivot and calculate sum of in+out in the map. This should work as well:
import "date"
|> range(start: month)
|> group()
|> sum()
Tiki10
April 6, 2022, 12:27pm
8
ypnos:
import "date"
|> range(start: month)
|> group()
|> sum()
Hello Ypnos,
Thank you for your reply and your help.
In fact, the way how I try to get values is wrong.
bytesIn and bytesOut are counter, so they are alway incremented.
With $month variable, I’m able to know from how much this counter was incremented since the begin of the month.
This is the queries I’m using (thank for Slack help):
import "date"
|> range(start: month)
|> increase()
And the same for bytesOut.
If I want to know the sum of bytesIn or bytesOut, I can use my calculator or use the Grafana Transform (not working as good as it should do) or use Flux to make the sum of consumption In and Out. This is where I fail.
could I put the result of query in variable and then sum these queries ?
regards
scott
April 6, 2022, 3:48pm
9
@Tiki10 You should only need one query for the evolution line graph. This should work:
import "date"
|> range(start: month)
|> increase()
And for the sum total of both bytesIn and bytesOut since the beginning of the month:
import "date"
|> range(start: month)
|> increase()
|> group()
|> sum()
This is a combination of your current query and what @ypnos is suggesting.
