i have several energy meters and want to get the total consumption using flux but i dont get it, any hint ?
I simply want to get the sum of p1,p2 and p3 (all 3 and also the total) for all enrgy meters. The timestamp is the same for all meters as i write it all at the same time with the same timestamp using GitHub - ardiehl/emModbus2influx: Modbus to InfluxDB (v1/v2) and/or MQTT
This is my source for 3 meters (i have more)
g1 = from(bucket: “ad”)
|> filter(fn: (r) => r[“_measurement”] == “energyMeter”)
|> filter(fn: (r) => r[“Device”] == “G1”)
|> filter(fn: (r) => r[“_field”] == “p1” or r[“_field”] == “p2” or r[“_field”] == “p3”)
g2 = from(bucket: “ad”)
|> filter(fn: (r) => r[“Device”] == “G2”)
g3 = from(bucket: “ad”)
|> filter(fn: (r) => r[“Device”] == “G3”)
grant1
March 30, 2023, 11:07pm
2
Welcome @Armin_Diehl
You can have one query with a group() and sum() function. I do not see why you would need the aggregateWindow() function.
from(bucket: "junkbucket") // change this to your bucket name
|> filter(fn: (r) => r["_measurement"] == "energyMeter")
|> filter(fn: (r) => r["Device"] == "G1" or r["Device"] == "G2" or r["Device"] == "G3")
|> filter(fn: (r) => r["_field"] == "p1" or r["_field"] == "p2" or r["_field"] == "p3")
|> group(columns: ["_field", "_measurement"], mode:"by")
|> sum(column: "_value")
|> yield(name: "sum_of _field_values")
gives us the totals for p1, p2 and p3:
|> group(columns: ["Device", "_measurement"], mode:"by")
|> yield(name: "sum_of _field_values_by_device")
gives us the totals for G1, G2 and G3:
If you want the grand total, just insert another group() and sum() function like this:
Thnaks a lot, that pointed me to the solution. However, i dont wnat to have the totals but the totals of all power per time, this woked for me:
from(bucket: "ad")
|> filter(fn: (r) => r["Device"] == "Allgemein" or r["Device"] == "G1" or r["Device"] == "G2" or r["Device"] == "HK" or r["Device"] == "Halle")
|> group(columns: ["_time","_field"])
|> group(columns: ["_value", "_time"], mode: "except")
|> yield(name: "sum_of_all_meters_per_phase")
and for the sum of all phases
from(bucket: "ad")
|> group(columns: ["_time"])
|> set(key: "_field", value: "p")
|> yield(name: "sum_of_all_meters_and_phases")
however, here the set does not work in grafana, the field name is shown as _value ?
grant1
March 31, 2023, 8:02pm
5
Try this…
|> rename(columns: {_value: "something"})
works fine, thanks for your support
grant1
March 31, 2023, 10:31pm
7
@Armin_Diehl Please mark the above as Solution if it indeed resolved your question, so that others may find it in the future.
