Hello @YellowSub,
yes Flux is quite challenging at first but once you understand it, it opens up a lot more possibilities /offers more power.
There are two main ways I can think about solving this problem:
import "csv"
csvData = "#group,false,false,true,true,false,false,true,true,true
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,double,string,string,string
#default,mean,,,,,,,,
,result,table,_start,_stop,_time,_value,_field,_measurement,location
,,0,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T11:00:00Z,83.75,degrees,average_temperature,coyote_creek
,,0,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T12:00:00Z,81.5,degrees,average_temperature,coyote_creek
,,0,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T13:00:00Z,79.5,degrees,average_temperature,coyote_creek
,,1,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T11:00:00Z,0.9810000000000001,water_level,h2o_feet,coyote_creek
,,1,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T12:00:00Z,0.6603000000000001,water_level,h2o_feet,coyote_creek
,,1,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T13:00:00Z,1.2026999999999999,water_level,h2o_feet,coyote_creek
,,2,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T11:00:00Z,3.87275,water_level,h2o_feet,santa_monica
,,2,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T12:00:00Z,3.5991,water_level,h2o_feet,santa_monica
,,2,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T13:00:00Z,3.1909,water_level,h2o_feet,santa_monica
,,3,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T11:00:00Z,73.75,degrees,average_temperature,santa_monica
,,3,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T12:00:00Z,81.9,degrees,average_temperature,santa_monica
,,3,2021-11-28T10:35:11.432769193Z,2021-12-28T10:35:11.432769193Z,2021-11-28T13:00:00Z,79.2,degrees,average_temperature,santa_monica
data = csv.from(csv: csvData)
|> range(start: -30d, stop: now())
|> filter(fn: (r) => r["_measurement"] == "h2o_feet" or r["_measurement"] == "average_temperature")
|> filter(fn: (r) => r["_field"] == "degrees" or r["_field"] == "water_level")
|> filter(fn: (r) => r["location"] == "coyote_creek" or r["location"] == "santa_monica")
|> limit(n:3)
data
|> yield(name: "4 lines")
data
|> group()
|> pivot(rowKey:["_time"], columnKey: ["_field", "location"], valueColumn: "_value")
|> map(fn: (r) => ({ r with _value: r.degrees_coyote_creek + r.degrees_santa_monica + r.water_level_coyote_creek + r.water_level_santa_monica }))
|> yield(name: "solution 1")
data
|> group(columns: ["_time"], mode:"by")
|> sum(column: "_value")
|> group()
|> yield(name: "solution 2")
Solution 1 involves pivoting the data around the timestamp column…essentially transforming the table into a table you’d expect to see in a SQL db. Where the columns are field1_tag1, field1_tag2, field2_tag1…etc and the values of those columns are the values for those fields with those tags. Then you can use the map() function to sum across the columns on each row.
Solution 2 involves grouping on time so that you can add the values with the sum() function across these smaller tables that are grouped by time and then ungrouping with the empty group() function.
