I’m trying to achieve a summation on ‘segments’, but failing to do so. I hope somebody can help me out in the right direction.
What i’m trying to achieve is : ( for example )
Calculate the sumation of the max value :
segment 1 : 3000
segment 2 : 3133
segment 3 : 3128
segment 4 : 3199
segment 5: 3252
The total of this is 15712, and is what i’m trying to achieve.
Currently my flux script looks like ![]()
data = from(bucket: "....x")
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) => r._measurement == "${DeviceID}" and (r._field == ".....x"))
|> filter(fn: (r) => r......x> 0 )
//|> yield(name: "squared")
data1 = data
|> derivative(columns:[".....x"],unit: 10s, nonNegative: false)
|> filter(fn: (r) => r......x> 100 )
|> set(key: "Type",value: "TotalWeight")
//|> yield(name: "test")
union(tables: [data, data1])
|> pivot(rowKey:["_time"], columnKey: ["Type"], valueColumn: "....x")
|> filter(fn: (r) => r.TotalWeight > 0 )
//|> cumulativeSum(columns: ["null"])
I’ve tried using the cumulativeSum function, integral funtion etc etc… but not getting the result im looking for.
I hope someone can help me out.
Thanks,
Regards
