hanhoe
1
Good Morning!
I build my first bucket and the Grafana connect.
So far looks nice, but I was not able to sum two values:
from(bucket: "Database")
|> filter(fn: (r) => r["_measurement"] == "PV")
|> filter(fn: (r) => r["Wechselrichter"] == "1" or r["Wechselrichter"] == "2")
|> filter(fn: (r) => r["_field"] == "Aktuelle Leistung")
|> aggregateWindow(every: v.windowPeriod, fn: sum, createEmpty: false)
|> yield(name: "sum")
I would like to sum this 2 values to get the total active power from both inverter.
Thank you!
grant1
2
Hi @hanhoe
I think this is easiest done using a Transformation in Grafana. See below.
hanhoe
3
Hi @grant1
Thank you … in the meantime I found this solution:
|> group(columns: ["_time", "Aktuelle Leistung"])
|> sum()
|> group(columns: ["Aktuelle Leistung"])
|> sort(columns: ["_time"])
You think this is ok or better your way?
grant1
4
I do not think either is better than the other. Depends on your comfort level with Flux and Grafana’s options.
