I am trying to install on AWS, I have a “Canonical, Ubuntu, 18.04 LTS, amd64 bionic image build on 2020-09-03” instance and are following Step 1 - Install InfluxDB Enterprise meta nodes | InfluxDB Enterprise 1.8 Documentation
The installation keeps on timing out, any ideas?
–2020-09-07 06:30:04-- (try: 8) https://dl.influxdata.com/enterprise/releases/influxdb-meta_1.8.0-c1.8.0_amd64.deb
Connecting to dl.influxdata.com (dl.influxdata.com )|13.224.38.108|:443… failed: Connection timed out.
Connecting to dl.influxdata.com (dl.influxdata.com )|13.224.38.114|:443… failed: Connection timed out.
Connecting to dl.influxdata.com (dl.influxdata.com )|13.224.38.69|:443… failed: Connection timed out.
Connecting to dl.influxdata.com (dl.influxdata.com )|13.224.38.83|:443… failed: Connection timed out.
philjb
September 8, 2020, 2:32am
2
Can you access other external sites from within your aws instance? You might have a permissions issue with accessing outside resources. The link seems available.
It looks like a DNS issue in your AWS setup. The IP addresses it’s using for dl.influxdata.com are Amazon’s IPs, not InfluxData’s IPs.
When I run nslookup from inside my own AWS EC2 instance, I get:
nslookup dl.influxdata.com
Server: 172.30.0.2
Address: 172.30.0.2#53
Non-authoritative answer:
Address: 99.84.222.19
Address: 99.84.222.36
Address: 99.84.222.71
Address: 99.84.222.87
Thanks, I found the issue, but not a big enough security expert, the “security group” setup. So have oped up all the ports and it works.
So now I need to sharpen up my security knowledge, to block and open the correct ports.
