InfluxDB 3 cli client download link not available
In the docu the link is https://dl.influxdata.com/influxdb/releases/influxdb2-client--linux-arm64.tar.gz.
But this link is dead. With curl -0 you get only the XML information, not the file itself. wget doesn’t work, because there is no file.
Are you trying to download InfluxDB v2 or v3 as your post title says v3 but link is showing v2 ? All the versions can be found here InfluxData Downloads . Also please let me know where you found this link so we can investigate/fix it. Thanks.
I was trying to download for InfluxDB v3. The link from the download site works, thanks.
Where I found the link:
