Http 404 page not found
I have influxdb used to run smoothly. Yesterday, I upgraded the OS win2k16 to win2k19. When I run as usual on commandlline as you can see the output on the screen
influx.bat
2021-12-28T15:40:52.948006Z info InfluxDB starting {“log_id”: “0YhR3sKW000”, “version”: “1.7.4”, “branch”: “1.7”, “commit”: “ef77e72f435b71b1ad6da7d6a6a4c4a262439379”}
2021-12-28T15:40:52.948006Z info Go runtime {“log_id”: “0YhR3sKW000”, “version”: “go1.11”, “maxprocs”: 1}
2021-12-28T15:40:53.067008Z info Using data dir {“log_id”: “0YhR3sKW000”, “service”: “store”, “path”: “C:\Users\salam\.influxdb\data”}
2021-12-28T15:40:53.069008Z info Compaction settings {“log_id”: “0YhR3sKW000”, “service”: “store”, “max_concurrent_compactions”: 1, “throughput_bytes_per_second”: 50331648, “throughput_bytes_per_second_burst”: 50331648}
2021-12-28T15:40:53.069008Z info Open store (start) {“log_id”: “0YhR3sKW000”, “service”: “store”, "trace
2021-12-28T16:01:14.464066Z info opened HTTP access log {“log_id”: “0YhSE9aW000”, “service”: “httpd”, “path”: “stderr”}
2021-12-28T16:01:14.465066Z info Listening on HTTP {“log_id”: “0YhSE9aW000”, “service”: “httpd”, “addr”: “[::]:8086”, “https”: false}
2021-12-28T16:01:14.465066Z info Starting retention policy enforcement service {“log_id”: “0YhSE9aW000”, “service”: “retention”, “check_interval”: “30m”}
2021-12-28T16:01:14.465066Z info Listening for signals {“log_id”: “0YhSE9aW000”}
i can connect from command line and can issue different commands "show databases…Use…
but when I try to access the GUI at
http://localhost:8086/
I get
HTTP 404 Page not found
Here is the output from cli
Connected to http InfluxDB shell ve
Enter an InfluxQL
show databases
name
_internal
statty
telegraf
sierac
covid19
Is there any log for the http operations? I enabled
log-enabled = true
access-log-path = E:\Influx\influxdb-1.7.4-1\log
but still no log created. What might went wrong?
InfluxDB 1.x has no UI, therefore you get the 404 error.
For the Web UI in InfluxDBv1, you would need Chronograf.
Or upgrade to InfluxDBv2, where the UI is integrated.
I see, thanks for your response
