Hey,
I installed the influxDB 2.7.4 on my ubuntu sytem.
curl -O https://dl.influxdata.com/influxdb/releases/influxdb2_2.7.4-1_amd64.deb
sudo dpkg -i influxdb2_2.7.4-1_amd64.deb
Now the system ist running after.
sudo service influxdb start
sudo service influxdb status
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2024-02-12 12:59:24 CET; 6min ago
Docs: man:influxd(1)
Main PID: 472078 (influxd)
Tasks: 8 (limit: 4551)
Memory: 59.3M
CPU: 2.587s
CGroup: /system.slice/influxdb.service
└─472078 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913272Z lvl=info msg="Registered diagnostics client>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913335Z lvl=info msg="Starting precreation service">Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913368Z lvl=info msg="Starting snapshot service" lo>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913383Z lvl=info msg="Starting continuous query ser>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913398Z lvl=info msg="Starting HTTP service" log_id>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913411Z lvl=info msg="opened HTTP access log" log_i>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913674Z lvl=info msg="Listening on HTTP" log_id=0nJ>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.913699Z lvl=info msg="Starting retention policy enf>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.914327Z lvl=info msg="Storing statistics" log_id=0n>Feb 12 12:59:25 cben influxd[472078]: ts=2024-02-12T11:59:25.914595Z lvl=info msg="Listening for signals" log_id>
Did anyone has an idea what I need to activate?
Thanks in advance.
