Hello, I’m sure the question has already been asked several times. But don’t find a solution.
I want to access InfluxDB via ip: 8086 and get the message
“404 page not found”
this indicates that there is a connection but something is not yet ok
I’ve already tried a few things, unfortunately without success
on my raspberry I use
Connected to http://localhost:8086 version 1.8.3
InfluxDB shell version: 1.8.3
Grafana ist runnig fine too on my ip computer
[http]
# Determines whether HTTP endpoint is enabled.
enabled = true
# Determines whether the Flux query endpoint is enabled.
# flux-enabled = false
# Determines whether the Flux query logging is enabled.
# flux-log-enabled = false
# The bind address used by the HTTP service.
# bind-address = "localhost:8086"
# bind-address = ":8086"
# Determines whether user authentication is enabled over HTTP/HTTPS.
auth-enabled = true
