Hi,I have a measurement which has one tag value and one field value.
insert abc,temp=20 dept=12
select * from abc
time dept temp
1613553100294732034 12 20
show tag keys from abc
tagKey
temp
show field keys from abc
fieldKey fieldType
dept float
Now i want to swap the filed as tag and tag as field, is it possible to do in same measurement,if not how can we?
