A programming error in a script resulted in us preparing and uploading a Line Protocol file which included some invalid field key/value pairs; the file specified some fields with value 0 but the fields should not have been included at all.
The result is that a SHOW FIELD KEYS on the database shows many more fields than are appropriate for the measurement, and SELECT on a measurement series produces many more columns of output than we want. (Of course, we can specify the columns to display but * is much quicker to type!)
Is there some way to delete the incorrect fields from the measurement? (The fields in question need to be removed from all series in the measurement.)
Thanks,
Jeremy Begg
