Hi, Experts
as for the deletion of influxdb measurements, if i want to remove some fields from existing measurement in order to make the measurement looks simple and clean. but it seems not possible
> insert test,type="b" val=2 1504225728000123456
> select * from test
time caseAuthor caseName caseResult type val value
2017-09-01T00:28:48.000123456Z "b" 2
the old field name caseName and caseAuthor still there, I guess maybe i did not delete correctly by
Drop series from test
anyone could explain that to me
thanks
/Yijun
