mpaul
1
Is there a way to migrate or rename field-names and tagnames of a measurement , I am new to influx and need help.
I guess one can pull out all the data and load it back … but looking for a db-admin solution really if possible…
Any suggestions is appreciated.
MPaul
sbains
2
A Continuous query like solution should work; e.g.
SELECT t AS tnew, r AS rnew INTO measurementb FROM measurementa
Won’t be possible for tags
sbains
4
No update option available; you have to delete and add the data again into database.
