Convert field to tag
I wish ask you if there are any way to convert fields to tags on existing measurement with many points.
Regards
Ariel
@acanepalumile You will need to rewrite the data. I would suggest trying a SELECT ... INTO query. Does that help?
Hi @jackzampolin, thank you very much for your answer!
I have already used select … into, but the field that I need to convert to tag is still a field. Basically, I have a measurement with this fields:
SALA: tag
sector: field
and I need that the field “sector” convert to tag for use it as a filter in templating. This measurement has many points inside.
Please, can you give me further informtation about how does it works. How does the select into convert a field into tag?
Regards
Ariel
Be sure to use GROUP BY to identify the tags.
For example:
select * into B from A
all tags will be converted to fields.
select * into B from A group by T
and T will be a tag in B, not a field.
Hello Frank,
Thank you very much for your answer.
Regards
Ariel
I tried using this approach, but still my fields remain fields in the new measurement. Any ideas why?
My command:
select * into water_level from level group by location,level
I have failed with select into. Now I’m out of ideas! Pissed off!
