I’m reading data from InfluxDB in Grafana, and I want to do alerts using multiple values.
My data has unique _field, but no unique tag. This is an issue in Grafana Alerts, and I would like to somehow set the _field as a tag as well (copy).
I tried this approach:
But I’m not looking to write this to a new bucket, but rather have my query return with the extra tag.
It appears you were able to solve your problem, but as @Anaisdg said, the only way to get a tag into InfluxDB is the write a tag. In your case, I believe the way Grafana parses the result from InfluxDB is that if a _value column is found, it is assumed to be a time-series. The workaround is to add the following:
