This database is working very nicely in Grafana, but when I go to the DB in Influx to look at the data I can’t and get this error, any ideas what I can do to fix?
This is the PowerShell script that I use to populate the DB and it all works in Grafana I just can view anything when use Influx as I need to check the data.
I’m guessing it’s my scripts
Influx DB 1.8
