Yes, the code clock formatted “fancy” Unicode quotation marks in place of “ordinary” quotation marks. I use “ordinary” ASCII quotation. But I tested a lot of syntaxes and below the query and result of that query. Seams to be problem with dash (hyphen) in name maciej-test. Is any workaround or proper syntax to pass such name to CLI InfluxDB? As I wrote, everything works file from InfluxDB prompt.
influx -precision rfc3339 -format csv -database test -execute “select mean(“Hum”) as “Hum” from “autogen”.“maciej-test” GROUP BY time(1s) FILL(none) limit 6 tz(‘Europe/Warsaw’)”
And the answer:
ERR: error parsing query: found -, expected ; at line 1, char 44
Any idea what to do? I can not change the name of parameter “maciej-test”.
EDIT 1
If I use stdin as input for SELECT command, everything works fine, like below:
influx -database test -format csv -precision rfc3339 << ‘EOF’
EOF
Very strange…
