Hi Team ,
1.I am getting error while running the influx query
Query :-“SELECT “message” FROM “server_logs”.“autogen”.“sos_logs” where “path”=‘C:\FTAM24\SOS_logs\wrapper.log’ limit 10”
Error is coming like:-"ERR: error parsing query: found \F, expected identifier, string, number, bool at line 1, char 76
Could you help me with this condition?.
2.Similar kind of error i am also getting in Chronograf GUI below mention details
Query:"SELECT “message” FROM “server_logs”.“autogen”.“sos_logs” WHERE time > :dashboardTime: AND “path”=‘C:\FTAM24\SOS_logs\wrapper.log’ "
Error i am getting like:-“Request failed with status code 400”
Pooh
2
Hi Team ,
identifier, string, number, bool at line 1, char 76 "
Have you tried escaping the backslash characters in the query, such as:
details
My guess is the same solution will work for both problems.
Regards,
Antony.
Hi Antony,
our “path” tag column contain the value “C:\FTAM24\SOS_logs\wrapper.log”.
How I can change the original value of “path” tag column while running in influx query .
if I will escaping the backslash characters from the “path” tag column value definitely, I will not get the proper result.
Could you help me with one sample example?
Hi Team ,
i got the solution for the above issues,
Thanks a lots!!
