I plan to pull data from multiple SNMP devices, all of which have similar SNMP credentials. Wondering if it is possible to have a global instance of SNMP credentials so that I don’t need to reproduce for every device.
It isn’t possible, but you can use environment variables replacement in the configuration file:
[[inputs.snmp]]
agents = ["foo.example.org:161", "bar.example.org:161"]
version = 3
sec_name = "$SEC_NAME"
auth_protocol = "sha"
auth_password = "$AUTH_PASSWORD"
sec_level = "authPriv"
priv_protocol = "AES"
priv_password = "$PRIV_PASSWORD"
[[inputs.snmp.field]]
name = "hostname"
oid = "RFC1213-MIB::sysName.0"
[[inputs.snmp]]
agents = ["baz.example.org:161"]
version = 3
name = "sys_contact"
oid = "SNMPv2-MIB::sysContact.0"
You can specify all the agents with the same field/table settings together, and I also recommend splitting your config files into multiple files in /etc/telegraf/telegraf.d.
