I’m using Telegraf to snag lots of data via snmp and shove that into Influx. I have devices that cannot utilize the same security standards as our primary gear (v3, SHA, AES) – so I’m going to need to make entirely separate config [inputs.snmp] blocks to accommodate devices with different settings. How would I go about doing that?
Should look something like this:
[[inputs.snmp]]
agents = ["foo.example.org"]
version = 3
[[inputs.snmp.fields]]
name = "hostname"
oid = "RFC1213-MIB::sysName.0"
[[inputs.snmp]]
agents = ["bar.example.org"]
version = 2
name = "hostname"
Well that was easy. Thank you!
