I’m creating a webapp using Giraffe to display some time series data.
The chart automatically refreshes every x seconds and I want the refresh timer to be paused when a user has zoomed in on a chart.
Because my yDomain is set manually i can use onSetYDomain to check if someone used the brush zoom on the y domain. This however doesn’t work with the x domain because it is set automatically.
Is there a way for me to set the xDomain in ‘controlled’ mode without changing the xDomain?
