sake
April 22, 2023, 5:53pm
1
Hi I’m looking at giraffe for drawing some graphs.
Is there a way to rename the _time and _value fields in tooltip?
The table seems to support it but the properties field doesn’t seem to do anything if the type is “line”?
# Giraffe
[](https://www.influxdata.com/slack)
A React-based visualization library powering the data visualizations in [InfluxDB 2.0](https://github.com/influxdata/influxdb/) UI.
<img src="https://influxdata.github.io/branding/img/mascots/mascot-chronograf--white_png.png" height="100" alt="giraffe"/>
## Demos
[See the visualizations in action using Storybook](https://influxdata.github.io/giraffe)
## Quick Start
Giraffe can be used in a simple index.html page without any advanced configuration. Even though Giraffe is designed to work with React apps, you won't need React or Node.js to do the quickstart below.
In this quickstart, we're going to build a simple line graph using Giraffe in a single index file. All you'll need is a text editor.
1. Set up your `index.html` file:
```html
<!DOCTYPE html>
This file has been truncated. show original
Hello @sake ,
I apologize. Unfortunately this isn’t the place to get Giraffe support. I recommend creating an issue on the gh repo. Thank you.
