Hi there,
I would like to replace grafana by giraffe.
With the examples, I’m able to create a graph with a line of values, but I don’t know how to add a second line in the same graph.
Any example ?
Thank you
JeLeB
Hi there,
Any example ?
Thank you
JeLeB
What I have done. I’m not using JSX:
class PlotRenderer extends React.Component {
render() {
var style = this.props.style;
var tsSerie = this.props.tsSerie;
var valueSerie = this.props.valueSerie;
var tokenName = this.props.tokenName;
var gridColor = this.props.gridColor || "#d9d9d9";
var interpolation = this.props.interpolation || "monotoneX";
var lineLayer = {
type: "line",
x: "_time",
y: tokenName,
colors: ["green", "red", "yellow"],
interpolation: interpolation
var table = Giraffe.newTable(tsSerie.length)
.addColumn("_time", "dateTime:RFC3339", "time", tsSerie)
.addColumn(tokenName, "integer", "number", valueSerie)
var config = {
table,
layers: [lineLayer],
gridColor: gridColor
var SimplePlot = React.createElement(Giraffe.Plot, {config}, tokenName);
return React.createElement("div", {style}, SimplePlot);
And it’s called by
function renderGraf(component, props) {
var grafDiv = document.getElementById("graph_giraffe");
ReactDOM.render(
React.createElement(component, props),
grafDiv
renderGraf(PlotRenderer, props);
It works well with ine graph, but I want to give the user ti be able to add a graph for another valueSerie
he selects on the same tsSerie
(like in the example StoryBook
in line graph
tab)
Thank you for your help
Hello @jeleb,
that’s cool! Just out of curiosity what’s your use case? Can you tell me a little more about what you’re building?
Let me ask around
Hello @Anaisdg
My purpose is to create a graph with some element selected from a list of events. Events are named and counted in a InfluxDB v2, and the users can select all the events from the list they want to see in the same graph.
Hi @jeleb. It looks like you are trying to say that your data should show multiple lines in a single graph. To do so, your data must include a column that will identify separate lines. In addition, you must use the “fill” property in your lineLayer
So, in your code you must change:
var lineLayer = {
type: "line",
x: "_time",
y: tokenName,
fill: ["columnKey"], // REPLACE "columnKey" with the actual name of the column (the first argument to the addColumn function)
.addColumn("columnKey", "string", "string", ["line1", "line1",...,"line2", "line2"] // note: not real code, replace with real code with real column
Another example would be the quick start guide in our Giraffe repository, located here: giraffe/README.md at master · influxdata/giraffe · GitHub
Step 7 and 8 would look like this:
const lineLayer = {
type: "line",
x: "_time",
y: "_value",
fill: ["name"]
const table = Giraffe.newTable(6)
.addColumn('_time', 'dateTime:RFC3339', 'time', [1589838401244, 1589838461244, 1589838521244, 1589838401244, 1589838461244, 1589838521244])
.addColumn('_value', 'double', 'number', [2.58, 7.11, 4.79, 2.0, 6.5, 3.2])
.addColumn('name', 'string', 'string', ['line1', 'line1', 'line1', 'line2', 'line2', 'line2']);
Alternatively, another way instead of using “table” you may also use “fluxResponse” and use an annotated CSV string as the value for “fluxResponse”. something like this:
var csv = `#group,false,false,true,true,false,false,true,true,true,true
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,double,string,string,string,string
#default,_result,,,,,,,,,
,result,table,_start,_stop,_time,_value,_field,_measurement,cpu,host
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:57:30Z,20.679320679130722,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:57:40Z,11.711711711705151,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:57:50Z,10.600000000100117,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:00Z,10.38961038953676,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:10Z,18.20000000006985,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:20Z,10.29999999986845,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:30Z,10.11011011018491,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:40Z,12.187812187812478,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:50Z,13.213213213141474,usage_system,cpu,cpu0,my_computer
,,0,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:59:00Z,12.487512487500869,usage_system,cpu,cpu0,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:57:30Z,1.8018018018063948,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:57:40Z,0.7999999999992724,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:57:50Z,0.40000000000873115,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:00Z,0.39999999999054126,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:10Z,6.393606393612802,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:20Z,0.19999999998617568,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:30Z,0.30000000000654836,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:40Z,0.49999999999272404,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:58:50Z,0.30000000000654836,usage_system,cpu,cpu1,my_computer
,,1,2022-02-24T21:00:43.684788241Z,2022-02-24T22:00:43.684788241Z,2022-02-24T21:59:00Z,0.30000000000654836,usage_system,cpu,cpu1,my_computer`
var lineLayer = {
type: "line",
x: "_time",
y: tokenName,
fill: ["result", "_field", "_measurement", "cpu", "host"],
var config = {
fluxResponse: csv,
Beware of the spacing in the csv variable. it must be exactly as shown. See our documentation on annotated CSV for more information.
You can also adjust the “fill” property with fewer columnKeys in given example to see less or more information when you hover the graph
var lineLayer = {
type: "line",
x: "_time",
y: tokenName,
var config = {
fluxResponse: csv,
