[INFO] package: Creating packages for linux/amd64
[ERROR] run: Command ‘make -C man/ clean install DESTDIR=/tmp/influxdb-build.QRWYDi/linux/amd64/influxdb-1.8.3-1/usr’ failed with error: make: Entering directory `/code/src/github.com/influxdata/influxdb/man’
rm -f influxd.xml influxd-backup.xml influxd-config.xml influxd-restore.xml influxd-run.xml influxd-version.xml influx.xml influx_inspect.xml influx_stress.xml influx_tsm.xml influxd.1 influxd-backup.1 influxd-config.1 influxd-restore.1 influxd-run.1 influxd-version.1 influx.1 influx_inspect.1 influx_stress.1 influx_tsm.1
ASCIIDOC influxd.xml
XMLTO influxd.1
make: *** [influxd.1] Error 127
rm influxd.xml
make: Leaving directory `/code/src/github.com/influxdata/influxdb/man’
