Originally published at: Release Announcement: InfluxDB OSS 2.0.3 - InfluxData
A new maintenance release for InfluxDB OSS is available now. Thank you to all the community members who have downloaded and used this latest release. We’ve gotten a couple of important defects addressed here and made some other improvements based on early feedback.
- InfluxDB 2.0.3 — release notes
New Packaging
Preview: ARM64 Builds
Most importantly, we have our initial builds for ARM64 available. You will find on the downloads page ARM64 packages now available including DEB and RPM along with the usual generic Linux tarball. Please consider these preview releases. We are eager to work with our community members on ensuring that these are working well for everyone running ARM64!
DEB and RPMs
We’ve renamed the InfluxDB v2 DEB and RPM packages to clarify versions. The package name is now influxdb2 and conflicts with any previous influxdb package (including initial 2.0.0, 2.0.1, and 2.0.2 packages).
This release also defines v2-specific path defaults and provides helper scripts for influxd upgrade and cleanup cases.
This maintenance release of InfluxDB OSS includes the following fixes and improvements:
- Upgrading from 1.x to 2.x
- We’ve made an important change to how the
influxd upgradecommand works in terms of the handling of the underlying configuration file to make the behavior more consistent. Check the release notes for more details. If you’ve already upgraded, you may need to supply the--v2-config-pathwhen you restart, if the location of theconfig.tomlended up in an a-typical location based on the previous behavior.
- Selective delete of data
- Previously, you would have to drop the entire bucket of data to clean-up errors or issues. With this release, you can now selectively drop data using the delete CLI or API directly.
- CLI improvements
- Allow password to be specified as a CLI option for both
influx v1 auth createandinflux v1 auth set-password. - We improved ID-related error messages for
influx v1 dbrpcommands.
- Flux and LSP Support
- Flux has advanced to version 0.99. See the release notes for more details including the introduction of dictionary types which support key-value lookups.
- LSP has also advanced to version 0.5.25 within the browser to address some minor issues.
If you find issues or have questions, please join our InfluxDB Community Slack, post them in our InfluxDB GitHub Repo or our Community Site and we will take a look.
