I’m trying to build influxdb 2.0.2 from a release tarball (https://github.com/influxdata/influxdb/archive/v2.0.2.tar.gz), with these commands:
export GO111MODULE=on
export CGO_CPPFLAGS="${CPPFLAGS}"
export CGO_CFLAGS="${CFLAGS}"
export CGO_CXXFLAGS="${CXXFLAGS}"
export CGO_LDFLAGS="${LDFLAGS}"
make
but it fails complaining that there’s no git repository. is compiling from a source tarball supported?
==> Starting build()...
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Makefile:89: warning: overriding recipe for target 'bin/linux/influx'
Makefile:86: warning: ignoring old recipe for target 'bin/linux/influx'
make -C http all
make[1]: Entering directory '/tmp/x/src/influxdb-2.0.2/http'
go generate -x
go: downloading github.com/influxdata/flux v0.95.0
# get https://proxy.golang.org/github.com/influxdata/flux/@v/v0.95.0.zip
# get https://proxy.golang.org/github.com/influxdata/flux/@v/v0.95.0.zip: 200 OK (0.647s)
env GO111MODULE=on go run github.com/kevinburke/go-bindata/go-bindata -o swagger_gen.go -tags assets -nocompress -pkg http ./swagger.yml
make[1]: Leaving directory '/tmp/x/src/influxdb-2.0.2/http'
make -C ui all
make[1]: Entering directory '/tmp/x/src/influxdb-2.0.2/ui'
yarn install
yarn install v1.22.10
warning You don't appear to have an internet connection. Try the --offline flag to use the cache for registry queries.
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
warning monaco-languageclient@0.11.0: The engine "vscode" appears to be invalid.
warning vscode-languageclient@5.3.0-next.9: The engine "vscode" appears to be invalid.
info fsevents@1.2.12: The platform "linux" is incompatible with this module.
info "fsevents@1.2.12" is an optional dependency and failed compatibility check. Excluding it from installation.
info fsevents@2.0.7: The platform "linux" is incompatible with this module.
info "fsevents@2.0.7" is an optional dependency and failed compatibility check. Excluding it from installation.
[4/5] Linking dependencies...
warning " > connected-react-router@6.8.0" has unmet peer dependency "react-router@^4.3.1 || ^5.0.0".
warning Workspaces can only be enabled in private projects.
[5/5] Building fresh packages...
Done in 14.41s.
yarn build
yarn run v1.22.10
$ yarn install --silent && yarn build:ci
$ yarn generate && yarn build:vendor && webpack --config webpack.prod.ts --bail
$ oats ../http/swagger.yml > ./src/client/generatedRoutes.ts
$ webpack --config webpack.vendor.ts
Hash: 2a8b5684d35004117057
Time: 4198ms
Built at: 19/11/2020 20:42:59
Asset Size Chunks Chunk Names
vendor.bundle.js 15.2 MiB vendor [emitted] [big] vendor
1.bundle.js 1.57 MiB 1 [emitted] [big]
2.bundle.js 921 KiB 2 [emitted] [big]
json.worker.js 898 KiB [emitted] [big]
editor.worker.js 472 KiB [emitted] [big]
3.bundle.js 464 KiB 3 [emitted] [big]
4.bundle.js 63.7 KiB 4 [emitted]
55.bundle.js 33.7 KiB 55 [emitted]
38.bundle.js 30.5 KiB 38 [emitted]
35.bundle.js 25.4 KiB 35 [emitted]
53.bundle.js 23.2 KiB 53 [emitted]
30.bundle.js 21.4 KiB 30 [emitted]
37.bundle.js 21.1 KiB 37 [emitted]
11.bundle.js 20.2 KiB 11 [emitted]
47.bundle.js 19.5 KiB 47 [emitted]
34.bundle.js 18.1 KiB 34 [emitted]
45.bundle.js 17.7 KiB 45 [emitted]
43.bundle.js 14.4 KiB 43 [emitted]
36.bundle.js 13.9 KiB 36 [emitted]
5.bundle.js 13.2 KiB 5 [emitted]
59.bundle.js 12.5 KiB 59 [emitted]
56.bundle.js 12.2 KiB 56 [emitted]
51.bundle.js 11.4 KiB 51 [emitted]
20.bundle.js 10.8 KiB 20 [emitted]
0.bundle.js 10.8 KiB 0 [emitted]
40.bundle.js 10.5 KiB 40 [emitted]
60.bundle.js 9.86 KiB 60 [emitted]
61.bundle.js 9.66 KiB 61 [emitted]
7.bundle.js 9.27 KiB 7 [emitted]
13.bundle.js 8.88 KiB 13 [emitted]
27.bundle.js 8.8 KiB 27 [emitted]
21.bundle.js 8.66 KiB 21 [emitted]
29.bundle.js 8.42 KiB 29 [emitted]
15.bundle.js 8.23 KiB 15 [emitted]
63.bundle.js 7.95 KiB 63 [emitted]
12.bundle.js 7.85 KiB 12 [emitted]
39.bundle.js 7.79 KiB 39 [emitted]
6.bundle.js 7.76 KiB 6 [emitted]
41.bundle.js 7.75 KiB 41 [emitted]
46.bundle.js 7.54 KiB 46 [emitted]
48.bundle.js 7.5 KiB 48 [emitted]
57.bundle.js 7.49 KiB 57 [emitted]
25.bundle.js 7.19 KiB 25 [emitted]
42.bundle.js 7.12 KiB 42 [emitted]
24.bundle.js 7.11 KiB 24 [emitted]
44.bundle.js 6.92 KiB 44 [emitted]
52.bundle.js 6.91 KiB 52 [emitted]
58.bundle.js 6.77 KiB 58 [emitted]
18.bundle.js 6.71 KiB 18 [emitted]
23.bundle.js 6.64 KiB 23 [emitted]
17.bundle.js 6.44 KiB 17 [emitted]
54.bundle.js 6.41 KiB 54 [emitted]
32.bundle.js 6.37 KiB 32 [emitted]
28.bundle.js 6.15 KiB 28 [emitted]
31.bundle.js 6.04 KiB 31 [emitted]
19.bundle.js 5.94 KiB 19 [emitted]
26.bundle.js 5.25 KiB 26 [emitted]
10.bundle.js 5.07 KiB 10 [emitted]
33.bundle.js 5.05 KiB 33 [emitted]
16.bundle.js 4.96 KiB 16 [emitted]
49.bundle.js 4.59 KiB 49 [emitted]
9.bundle.js 4.55 KiB 9 [emitted]
50.bundle.js 4.35 KiB 50 [emitted]
62.bundle.js 4.35 KiB 62 [emitted]
22.bundle.js 3.3 KiB 22 [emitted]
14.bundle.js 3.27 KiB 14 [emitted]
8.bundle.js 2.9 KiB 8 [emitted]
+ 1 hidden asset
Entrypoint vendor [big] = vendor.bundle.js
Error: Command failed: git rev-parse HEAD
at checkExecSyncError (node:child_process:636:11)
at Object.execSync (node:child_process:672:15)
at /tmp/x/src/influxdb-2.0.2/ui/src/utils/env.ts:5:8
at Object.<anonymous> (/tmp/x/src/influxdb-2.0.2/ui/src/utils/env.ts:62:3)
at Module._compile (/tmp/x/src/influxdb-2.0.2/ui/node_modules/v8-compile-cache/v8-compile-cache.js:192:30)
at Module.m._compile (/tmp/x/src/influxdb-2.0.2/ui/node_modules/ts-node/src/index.ts:473:23)
at Module._extensions..js (node:internal/modules/cjs/loader:1131:10)
at Object.require.extensions.<computed> [as .ts] (/tmp/x/src/influxdb-2.0.2/ui/node_modules/ts-node/src/index.ts:476:12)
at Module.load (node:internal/modules/cjs/loader:967:32)
at Function.Module._load (node:internal/modules/cjs/loader:807:14)
at Module.require (node:internal/modules/cjs/loader:991:19)
at require (/tmp/x/src/influxdb-2.0.2/ui/node_modules/v8-compile-cache/v8-compile-cache.js:161:20)
at Object.<anonymous> (/tmp/x/src/influxdb-2.0.2/ui/webpack.common.ts:13:5)
at Object.<anonymous> (/tmp/x/src/influxdb-2.0.2/ui/webpack.prod.ts:4:16)
error Command failed with exit code 1.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
make[1]: *** [Makefile:16: build] Error 1
make[1]: Leaving directory '/tmp/x/src/influxdb-2.0.2/ui'
make: *** [Makefile:80: ui] Error 2
==> ERROR: A failure occurred in build().
Aborting...
