When I try to create a bucket in CLI, it is showing an error as “Organization not found”. But when I try to see by using the command influx config list, it is displaying the organization name.
Regards
Sudheer
Regards
Sudheer
Please copy and paste (not screenshots):
The command you are entering and the error you see.
The (appropriate section of the) output from ‘influx config list’
Antony.
I am using influx 2.1 version windows OS.
I am entering the below command in CLI to see the Org
influx config list
It is working fine. When I try to create bucket using influx bucket create --name bucket1. it is showing error as org not found
Regards
Sudheer
Try:
influx bucket create -n BucketName -o MyOrg -r 7d
You need to specify the Organisation to which the bucket will belong, plus the
Retention Policy.
Antony.
Still the same error I am getting.
Regards
Sudheer
Unless there is something secret about the name of your organisation, please
can you show us:
The part of the output from “influx config list” which shows the organisation
name
The exact command you are typing to create the new bucket.
Thanks,
Antony.
