I’m trying to run the following command, after setting up my db and I get this error
Please, what could I be doing wrong?
At first check in the UI what is the organization, token and type the same organization, token in the CLI, then config will be created. After that you can create buckets. I also faced the same issue
Regards
Sudheer
Thanks for your help!
Please can tell me the correct command to type to do this?
Please type the below command in CLI
influx config create --active \
-n config-name \
-u http://localhost:8086 \
-t mySuP3rS3cr3tT0keN \
-o example-org
This is in Windows CLI. Here t is the token.
