Hi all, I want to delete the single data point with a value of 0
My command is
influx delete \
--bucket dht22 \
--org esp8266 \
--token 4WW43qswEQUdpTnWedvhuyQa8ftEgi0vJNv6zfTV0bOhtSdrMYei-MJYSCpawRxcKkNs1NBrMf1ORV0kxdMK23D== \
--start 2023-01-28T08:54:20.000Z \
--stop 2023-01-28T08:54:20.000Z
Running it as root from a terminal, it seems to accept the command but the data point is still there?
Got it, had to select the data point before and the one after the actual point I wanted to delete.
--start 2023-01-28T08:54:05.00Z \
--stop 2023-01-28T08:54:45.00Z
@HenrysCat
Thanks for sharing your solution! PS what do you use influxdb for?
Logging temperature and humidity readings and sending to Grafana, will have over 10 sensors eventually.
you should probably censor your org, bucket and token and delete the token you posted from your database
