Seems its some problem with the authorization using the docker UI interface which I not are able to solve. Instead I try other ways to delete the specific samples by using the inbuilt influxDB UI, Grafana and NodeRed but I do not succeed to find a way here either. I can access the data (read and write) via NodeRed / Grafana but do not understand the flux command how to delete. Need some guidance here, Thanks.
Is it Flux or CLI that are the best alternative to delete specific samples?
Recommended and easiest InfluxDB client using windows?
